Need help identifying this C1 ignition shielding top - NCRS Discussion Boards
  • Ridge K.
    • May 31, 2006
    • 1018
    Help needed.
    I'm helping a good friend with his restoration of an early '59 fuelie.
    What is this original ignition shielding top, correct for?
    It is what I have commonly heard referred to as a "tall skirt" top.
    Measures about 5 and 1.2 inches high.
    Measures about 19 inches across at the bottom (base)
    Measures about 16 inches across on top, from corner bend to corner bend.
    Depth measures about 4 and 3/8ths inches wide, on the top, at the "distributor buldge".
    Appears to be stainless steel, but a strong magnet will stick.
    Does not appear to be flash chrome plated.
    Applications?
    Thanks in advance for any help. Ridge
  • Doug F.
    • November 1, 1983
    • 322
    Re: Need help identifying this C1 ignition shielding top
    ridge, that looks like a 62 over the counter carburated cover to me, attached are a few pics of an original 58 FI cover
    • Mike E.
      • February 28, 1975
      • 5153
      Agree with Doug, although the lower right in the picture from behind is hard to see and determine exactly how the cutout is done.
      • Ridge K.
        • May 31, 2006
        • 1018
        Thanks so much for the help., Doug, and Mike.
        Those photos are a huge, huge help, Doug. I appreciate it very much.
        Here's a couple more pics of the backside cutouts.
        • Mike E.
          • February 28, 1975
          • 5153
          Doug nailed it.
          • Ridge K.
            • May 31, 2006
            • 1018
            Thanks again guys.
            Another technical discussion board, success story!
            Ridge
