75 Coil Spring Label - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    The original Coils Springs on my 75 still had the green labels on them. The code was "AJ" and the number was 346940. I believe them to be the originals but have no absolute proof. The NCRS Judging Guide shows the AJ code as N/A for 75?? Can anyone verify that the AJ-346940 label was used in 75. See pics of original coil spring label
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Tom R.
    • June 30, 1993
    • 4102
    Re: 75 Coil Spring Label
    Alger
    Very nice. My data shows the AJ used in 76 for Corvettes with spring weight of 761-800 pounds, same as NCRS Tech guide.
    I show 75 using only two springs: an AH and an AY...and so does the 75-77 tech reference guide.
    What's peculiar is that the 76 part numbers, such as the 346940 fall in line with the 75 sequence...346939 and 346943.
    this is where I go to my build sheet inventory but I have only a few for 75-76 and what I do have for 75 conflicts with the NCRS tech guide. go figure.
    Here are my theories:
    So what's the build date of your 75? A late 75 which may suggest it was subject to 76 broadcast codes.
    75-77 tech manual is not current in this respect and in need of further research. I say this because my build sheets show both a AA for front coild springs and an HY...does not reconcile with published documents. I trust the build sheet.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Alger R.
      • 279
      My 75 Build date was April 2nd 1975. (VIN 1Z67J5S421273) It is a convertible L48 4 spd with air.
      I would hope that the AJ Coded Coil Spring was indeed introduced prior to that date.
      AL
      AL
      75 Convertible
      L48 M20
