C1 sheet metal shield under transmission tunnel - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1124
    Can someone comment on the sheet metal shield under the transmission tunnel on my 59? I have read a few other threads that seem to indicate this is original. However, a friend with a 60 advises his car does not have the sheet metal shield. I also see the shield in this thread:
    https://www.forums.ncrs.org/showthread.php?t=57952&highlight=transmission+tunn el+metal&uid=8757
    Is this original and what is its purpose if so?
  • Jim H.
    • April 1, 2002
    • 112
    Re: C1 sheet metal shield under transmission tunnel
    Not sure about 59's. I know 61/62 had the tunnel brace. Have you looked at the 59 AIM? I looked on one of the 60' body I had and can see it is there also. So not sure...
    • Stewart A.
      • April 16, 2008
      • 1035
      Maybe ask Tim Mickey Ian. It looks like it should be there ! I can't remember mine having one when it was up on the lift.
      I personally put the tranny in and cross member so I thought I would of seen something like you have if it was there ? HHMMM someone must have an idea hello out there.
      Stewy
      • Tom P.
        • April 1, 1980
        • 1815
        My 56 has one.
        • Mike M.
          • May 31, 1974
          • 8400
          both my 57's have the metal stamped steel plates. i'd guess their purpose is to protect the fiberglas floorpan in the event of a front u-joint failure. perhaps the Dipstick of Lyle( aka U-Joints-R-Us) can comment.mike
          • Dennis A.
            • April 30, 1999
            • 1010
            Never seen any sheet metal shields on 61 & 62's...58-60's had a had a separate piece screwed to the underbody, as did 56 & 57's
            • Roy B.
              • February 1, 1975
              • 7044
              It's there to proect your A*s from U-joint blow up ,all C1's had it my 55 also does riveted on.
              • Ian G.
                • September 3, 2007
                • 1124
                thanks a lot guys! Now I know not to remove it lol.
