1967 Heater Box - NCRS Discussion Boards
1967 Heater Box
  • Jeremy H.
    • December 31, 1998
    • 260
    1967 Heater Box
    On a 67 non A/C car is the outer heater box secured by speednuts that are silver or black?
    Jeremy Hedges
    #31711
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 1967 Heater Box
    Hi Jeremy
    The original speednuts were black phos (or dark gray)
    HaND
    • Jeremy H.
      • December 31, 1998
      • 260
      Re: 1967 Heater Box
      thanks for your help
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Re: 1967 Heater Box
        You're welcome!
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Re: 1967 Heater Box
          Oh, and don't forget the "Goop".
          HaND
          • Andrew P.
            • November 11, 2008
            • 84
            Re: 1967 Heater Box
            Yessss.... So exactly what is that GOOP? I need to seal mine soon....
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Re: 1967 Heater Box
              It was an asphaltic material, like undercoating, thinly sprayed along the seams of the box to the firewall as a seal to keep the engine fumes from entering the passenger compartment.
              Typically, applied rather sloppily with runs.
              Definitely not pressed-in like caulking.
              Occasionally, we have seen a few cars with a really tight fit in that area without the sealer, or maybe it was just an oversight.
              HaND
                • November 30, 1997
                Re: 1967 Heater Box
                That was a water test repair sealer - same stuff used in later years on grommets; it wasn't specified as part of the heater blower box installation, but was obviously used on-and-off as a preventive measure.
                • Rick S.
                  • December 31, 2002
                  • 1203
                  Re: 1967 Heater Box
                  Andrew,
                  Here is a shot of my Goop.
                  Rick
