Grill Plate - NCRS Discussion Boards
Grill Plate
  • Roger W.
    • January 29, 2008
    • 572
    Grill Plate
    Are the plates (part # 3743617) that hold the grill teeth center bar assembly to the front bumbers on a 59 supposed to be flat or are there any kind of bends in them. In the 1959 Assembly manual sect 13 sheet 2, that plate seems to be flat. Mine are slightly bent, but I suspect that they have been damaged.
  • Brian T.
    • September 30, 1990
    • 190
    Re: Grill Plate
    they are flat, I wonder if some previous owner modified them in order to work with 61-62 front bumpers?
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: Grill Plate
      If you tighten the plates on the studs to much they will bend.
      When new they are flat.
      • Roger W.
        • January 29, 2008
        • 572
        Re: Grill Plate
        Thanks for the replies. On closer examination, I think that the plates were customized by Crash.
        One other question that I forgot to ask. What kind of finish are they supposed to have?
