I am currently assembling my 75 L48 4 spd engine and am having a problem with the Lt Rr Side Ignition Shield interfering with the Clutch Cross Shaft Stud. I have the two retainer tabs properly positioned on the exhaust manifold. When I wing nut the shield on to the retainers the bottom directly interferes with the stud. I can lift the shield over the top but it sits tight against the stud and the cross shaft is not yet in place? I tried to maneuver the shield to decrease the interference but to no avail. I notice that an older shield for a 68-72 has a scallop recess in the bottom to clear the stud. My shield does not have the scallop recess but is supposed to be correct for 73 on up. Doesn't seem to fit...Help!
