60 Fuel inj. Tach, Cable speed? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    How can I recognize a 60 290hp fuel inj. tach? The redline should be 6500, is the cable speed twice or normal when it is feed from the distributor instead of the generator?
  • Brian T.
    • September 30, 1990
    • 188
    Re: 60 Fuel inj. Tach, Cable speed?
    The 290HP would be twice cable speed. There are early and late versions on 60 tachs. The early used white lines and numbers and the late was pale green.
    • Ray C.
      • June 30, 2001
      • 1132
      If the tach is operated off the distributor (high horse) it should have printed on the back of the tach, "Twice the cable speed"
      Ray
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • John D.
        • December 1, 1979
        • 5507
        Bill, All FI distributors turn 1/2 engine speed. How did you get to be a board member.
        • William B.
          • April 30, 1975
          • 939
          Thank you for the replys, I thought it was "twice cable speed", my mind is slow sometimes just wanted to check.
          John, where am I a board member? I just sit by and watch!
          • John D.
            • December 1, 1979
            • 5507
            Just teasing you Bill. You are doing a great job on the upcoming Al Grenning seminar on March 28th in Butler , PA.
            I see Bill that you have the seminar info on page 101 of the latest Driveline. John
            • Bill M.
              • April 1, 1977
              • 1386
              From a known-original '59 290: "registers twice cable speed"
