Is this a semi-gloss finish and is there a pair of borders to start and end. Difficult to determine the original finish through the rust. Also, my original band was silver exposed with the red inward. Replacements advertise silver or red. Is anyone producing the proper combo, silver over red? Grateful as always for any input you can provide, Mike
71 distributor housing finish
Tags: None
- Top
Re: 71 distributor housing finish
Mike, I remember buying my band from Paragon and used the red outward. I painted the complete distributor up to the part where it mounts (sits) on the engine.
The important things are not so much paint, check to make sure the advance bushing is still in place and no wear inside where the tach gear and distributor cast interface, wear here will surely eat the mainshaft.
- Top
As best I can determine from originals, semigloss black with bare machined surfaces appears to be the original finish.Bill Clupper #618- Top
Thanks guys,
Timothy, I'm assuming the Paragon tag was silver on one side and red on the other. I see the judging guide states that the red outward was the majority of the configurations. I removed my original with silver outward. An odd duck, I guess. Thanks again. Mike- Top
- Top
- Top
