I have problems to remove the rear crossmember - NCRS Discussion Boards
+ More Options
Posts
  • Hans R.
    • March 1, 1976
    • 91
    I started to remove my rear crossmember on my -66. I have no problems to remove the 2 bolts. But how do I remove the crossmember from the frame? The cushion seems to be stuck on the cushion steel sombrero. Before I start to be too violent, I thought I'd ask you experts out there if you have any magic tricks.
    Hans Ryden in Stockholm, Sweden
    Hans Ryden #868
    • 6948
    Re: I have problems to remove the rear crossmember
    Hans,
    I Saw A Post Recently With The Same Question, A Pry Bar Is All You Need , Wedge The Bar Between The Frame And Mount, Tap W/a Hammer, The Rust Causes The Crossmember To Almost Weld Its Self To Frame Its Only Been 40+ Years. Make Sure Everythings Supported, Once It Breaks Free It Will Drop.
    • Brian M.
      • February 1, 1997
      • 1840
      Spray it with a penetrant spray, put the bolts back in half way and use a long pry bar. You'll know when it pops.
      • Hans R.
        • March 1, 1976
        • 91
        Thanks for your quick replies. I will find a long pry bar.
        And yes, I saw the article on the -70 crossmember
        Hans Ryden #868
        • Tom R.
          • June 30, 1993
          • 4100
          Just dropped the rearend on my 78 and as they say it "pops" when it drops. I used a crowbar and wedged it up between frame and crossmember. The driver's side popped very easy in comparison to the passenger's side. Took many more umphs
          Tom Russo
          โ€‹
          78 SA NCRS 5 Star Bowtie
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Dick W.
            • 10483
            When they say pry bar, they do not mean a 18" bar. I have a 5' "pinch" bar that I use and sometimes it takes quite a while to dislodge the bushings. Just be careful. Leave the bolts loose, but in the crossmember or put a floor jack under the differential, leaving about 1/2" clearance.
            Dick Whittington
            • Michael M.
              • February 15, 2007
              • 455
              Yes, a 5' pry bar is what I use. With the wheels removed, come in from the side of the car. If it has been 40 years, be prepared to put your weight into it.
