Runs good when running on the center carb, back fires though the mufflers when floored, then takes off. On hooked the back carb and does the same, only half as bad. At idle, then floored, it almost dies, then takes off. Timeing is ok, points are ok, took one plug out tonight, looked ok, they are r43xls. Just bought the car in Washington state, I live in S.D., could the jets needs to be changed?
1967 435hp ?
