What are these Brackets?? - NCRS Discussion Boards
  • Jake D.
    • August 31, 1984
    • 134
    I was cleaning out some parts, and I ran across these brackets. I'm sure they are for a Corvette, but I don't know what years they belong to!
    If you need any one of them, just pay the shipping, and you can have them.
    • 43211
    Re: What are these Brackets??
    Jay-----
    The first photo is of an array of manifold-mounted engine lift brackets. These look like pre-1970 small block brackets to me. I'm not sure that all of them are Corvette, though. The one on the left is definitely Corvette.
    The other 2 brackets I do not recognize
    • Jake D.
      • August 31, 1984
      • 134
      Thanks Joe- The bracket in the middle looks like it would be a holder for a heater hose, late 50's or early 60's. The black bracket was a guide for the wires going to the starter. I think it's for a big block, although I don't know what year.
      • Mike E.
        • February 28, 1975
        • 5137
        Can't tell for sure by the pic, but the middle one could very well be the bracket that holds the lower portion of the road draft tube to the bolt on the bellhousing.
        • Mike M.
          • May 31, 1974
          • 8381
          picture of the metal clip isn't all that informative but it appears the end of the clip with hole drilled thru it is a single piece of steel whereas the road draft tube retainer has two layers of steel for the bolt to go thru. hence, i doubt its a c-1 raod draft tube. mike
          • Stewart A.
            • April 16, 2008
            • 1035
            I know, I know it's something off a car. I bet you 10 bucks !!!
              • 15596
              The left most of the engine lift brackets (first picture) has the same shape as the front lift bracket on my 1970 LT1. Of course being all Orange it didn't come from an LT1, but could be from a 1970 earlier base of L46.
