I'm racking my brain here.
I have had an issue with my 54 fuel pump losing pressure after about 5 minutes of running. I set up an in-line pressure gauge at the front carb and it showed a 6 Lb pressure at cold operation. After about 5 minutes of running the pressure has dropped to less than 1/2 lb. At first I suspected the fuel pump diaphragm, so I rebuilt the pump, replacing both the fuel and vacuum sections diaphrams and check valves. Still the same issue. I also tried running a hose line from a can of gas to the pump inlet, eliminating any vacuum leaks in the tank line. Still drops to 1/2 lb!
What the he__
Any suggestions anyone?
Joe
What the he__
Joe
