55 Transmission Oil - NCRS Discussion Boards
55 Transmission Oil
  • Fenwick B.
    • January 1, 2005
    • 115
    55 Transmission Oil
    I have put about 600 miles on my 55 since I have had the transmission and engine rebuilt, and I have just changed the Mobil1 oil in the engine for the second time. The oil did not have any metal visible, and I couldn't pick up anything with a magnet, so I think that it's Ok. The transmission was rebuilt about 2002, but I didn't put oil in it until 2007. I have been running the car since then, and I have never changed the transmission oil. The car runs good, but I was wondering if I should change it, and what type of oil I should use if I do change it? Fenwick
  • Larry M.
    • January 1, 1992
    • 2691
    Re: 55 Transmission Oil
    Fenwick:
    What transmission are you running in the car? A PG or 3-speed?
    What viscosity Mobil 1 are you running and do you know the ZDDP level? You may want to consider an oil with a higher ZDDP level or add a supplement. Mobil 1 website lists each oil and their specifications, zinc levels, etc.
    If you have a PG, you can still get the old Type A fluid, but I believe the current DEXRON fluids will also work okay. If a 3-speed, GM sells an 80-90W fluid that should work for you. I can get the part number if needed. What are you using now?
    Larry
    • Fenwick B.
      • January 1, 2005
      • 115
      Larry, it's a powerglide two speed, and i'm using Dextron in it. I am using Mobil1 10W30 in the engine.
        • 15672
        Mobil 1 is an API SM oil designed for modern engines. Vintage engines are better served with a CJ-4 or CI-4 oil
        • Fenwick B.
          • January 1, 2005
          • 115
          Thanks Duke, I will do that next oil change. Do you think the initial transmission oil should be changed with so few miles on it?
          • Roy B.
            • February 1, 1975
            • 7044
            No as longe as it's RED in color
              • 15672
              I'm not that familiar with the old Powerglides, so I have to defer to those who have experience with them, but I would think that the current Dexron is okay.
              As far as changing, you should first look at GM's recommendation for that era. I recall in the seventies the TurboHydramatic recommended service interval was 30K miles and it included changing the internal filter, but I don't know what the recommended service interval was in 1955 or whether the PG has an internal filter.
              Since today's ATFs are formulated from much more oxidation resistant blends of base oils than what was available when they were new, the OE recommended service interval should be more than adequate.
              The modern synthetic friction modifier to prevent wet clutch chatter (as is the case with Positraction axles) is also a lot more durable than the whale oil derived additive used in the old Type A Suffix A ATF from the fifties.
              With time the transmission fluid slowly oxidizes with heat and turns brownish or even black if it's really old and oxidized.
              • Larry M.
                • January 1, 1992
                • 2691
                Fenwick:
                I wouldn't worry about the PG. I believe that they have a filter/screen that should remove any debris. If you experience shifting issues, THEN I would pull the pan and check the filter and replace the fluid. With your annual miles, that fluid will last a lifetime
                About the engine oil, I have a case of 15W-40 CI-4 oil that I bought (overbought) a few years ago. I have more than enough for myself for years to come, so you are welcome to the case. Will deliver to next Chapter meet if you want. Otherwise, get some Shell Rotella. You can even get 10W-30 if you are willing to search a bit. Otherwise 15W-40 is fine for Louisiana year-around.
                Larry
                • Bert L.
                  • April 30, 1977
                  • 427
                  Interesting gizmo Roy, never seen one like it before. Hope it never decides to spring a leak into your lap!
                  "Keep 'em coming"
                  Best regards,
                    • 15672
                    Originally posted by Larry Mulder (20401)
                    Fenwick:
                    Otherwise, get some Shell Rotella. Otherwise 15W-40 is fine for Louisiana year-around.
                    Larry
                    There are plenty of other brands. Any big box or auto parts store has a section of C-category oil. I buy on price.
                    The commonly available 15W-40 is okay for cold starts down to about 10-15 degrees F, which should meet the needs of most owners who don't drive their vintage cars in the dead of winter. It's also suitable for triple digit temperatures where most of us will park our vintage Corvettes and opt for modern air-conditioned wheels.
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      "Keep 'em coming"
                      Best regards,
                      I've shown it before but people still have never seen one.Have had it in my 55 for years
                      You need it in your 60PG
                        • May 31, 1974
                        • 8383
                        Fenwick:
                        Larry
                        no tranny pan on a cast iron powerglide. mike
                        • Larry M.
                          • January 1, 1992
                          • 2691
                          Duke:
                          I agree. But down here on the bayou, Shell is a local brand/icon...and Fenwick is an old pipeline supervisor.
                          Larry
                          • Larry M.
                            • January 1, 1992
                            • 2691
                            Mike:
                            Thanks for the education. I learned on F*rd auto transmissions beginning in the early 60's. Didn't jump ship to Chevies until the 70's. Made a bad assumption.
                            Larry
