60 early 61 Top Tank Radiator Help - NCRS Discussion Boards
  • Paul M.
    • November 1, 1987
    • 142
    Doing the final assembly on my early 61 with a top tank radiator. Looking for the correct bolt length and the size of the rubber pads that are between the side brackets and the core. Thickness, length and width. Also are there 45's cut in the pads as are in the side brackets? Thanks in advance.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 60 early 61 Top Tank Radiator Help
    Paul--
    Good questions, can't help you on those, because I didn't ask those questions closely enough when surveying some early 61's 25-30 years ago.
    Here's a bump to the top, though.
    • Doug F.
      • November 1, 1983
      • 322
      paul, send me your email address and i'll send you some detailed photos of some original pads and bolts, cfaber@cox.net
      • Jim D.
        • 2885
        Why not post them here for all to see and use for future reference?
        • Doug F.
          • November 1, 1983
          • 322
          [quote=Jim Durham (8797);405563]Why not post them here for all to see and use for future reference
          the material looks like thick a inner tube and measures 1/8 of an inch, [ .125 ]
