Finally found it! - NCRS Discussion Boards
Finally found it!
  • Rob M.
    • April 30, 2003
    • 657
    Finally found it!
    I've been looking for a long time. Didn't see it on the doors when the panels were off, or behind the glove box when it was out, but today I found it. Bubba painted everything in the engine compartment black so I assumed it would be painted over too, but he was too lazy to go all the way down the footwell. With some cleaning . . . the job number appeared! It's written vertically and I think it is 137 (I know it looks like 131, but in person it looks like it is a 7). It's a good day.
  • Keith L.
    • April 7, 2008
    • 378
    Re: Finally found it!
    Looks like a 7 to me. A little lite on top but I see it.
    • Steven B.
      • June 30, 1982
      • 4009
      Congratulations!
      • Stuart F.
        • August 31, 1996
        • 4676
        I'd go with a "1".
        Stu Fox
        • Gerard F.
          • June 30, 2004
          • 3806
          Rob,
          Here is what I found on my 67 AOS car, passenger side firewall. Was just cleaning up the battery damage to the battery tray and frame below, and decided to use a little Simple Green on the firewall.
          Funny to find these things. I guess the AO Smith guys in 67 advanced to yellow crayon. It was horizontal.
          Jerry Fuccillo
            • 3418
            Hi Rob,
            It's a Great day!!!
            I'll vote 7. The angle of the photo lightens up the top swoosh.
            • Kirk M.
              • June 30, 2006
              • 1036
              Great find. Always cool to see something still there from the day the car was "built", even after all these years!
              Kirk
              • Paul J.
                • September 9, 2008
                • 2091
                Way to go, Rob. That idiot Bubba painted over mine when he was showing the car in the early 70's. Unfortunately, Bubba was me. At least I get a chance to correct the error of my ways.
                Paul
                • Chris E.
                  • November 3, 2006
                  • 1335
                  Agree with others who said "7". The numbers written on my passenger's side firewall bulkhead were very tall and narrow, just like yours. Probably the same guy that wrote them.....
                  Chris Enstrom
                  2011 Z06, red/red
                  • Rick S.
                    • January 1, 2003
                    • 1203
                    When they wrote the numbers on my car, someone forgot what they wrote first. On the passenger footwell, I have "60". Inside each door is "61".
                    • Chris E.
                      • November 3, 2006
                      • 1335
                      Rick, my car has a similar thing to yours. The tank stick says one number, and the number written on the car is two digits off. (174 vs 176 I think)
                      Chris Enstrom
                      2011 Z06, red/red
                      • Rick S.
                        • January 1, 2003
                        • 1203
                        Chris,
                        My understanding is that the tank sticker/build sheet numbers are different from the numbers on the pass footwell/doors/gas tank area. My tank sticker/build sheet hand written number is 137 which is 2 digits off my VIN which is 135. I bring this up to make sure you are not confusing the two.
                        Rick
                        • Stephen L.
                          • May 31, 1984
                          • 3162
                          The crayon numbers located on the floorpan, doors, and rear bulkhead will be the same. This number was also on the hood but was painted over during blackout. IMHO this number was assigned to keep track of those parts while in the body shop for fitment purposes. This number repeated every 500 bodies. It has nothing to do with the penciled number on the tank sticker. It appears that St louis used white crayons while AO SMITH used yellow crayons, based on the posted photos.....
                          In 1967 the penciled number on the tank sticker was usually within 1 or 2 digits of the VIN# and was always ahead. This penciled number also repeated every 500 so if your VIN ends in 345 then the penciled number would be 343 or 344. If your VIN ends in 845 then the penciled number would still be 343 or 344. 845 - (repeat 500) = 345.
                          Clear as mud????
                          • Brandon T.
                            • October 23, 2008
                            • 872
                            where is this number typically found of a 68? I'll look for mine!
                            btw I can see it looks like a 7 to me
                            • Chris E.
                              • November 3, 2006
                              • 1335
                              Rick and Steve, thanks for the detail. Good stuff to understand.
                              Chris Enstrom
                              2011 Z06, red/red
