c2 427 radiator drain - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    i just finished installing an original BB fan shroud in my 66. when i went to close the petcock i discovered that there was no clearance to turn the valve. the "ears" hit the shroud and the bottom mount. what type of drain or petcock was used on this aplication?
  • Douglas L.
    • August 31, 2003
    • 302
    Re: c2 427 radiator drain
    Bill,
    Brass plugs were also used on big blocks - probably because of the interference. One of my 67's has the plug.
    • Ridge K.
      • May 31, 2006
      • 1018
      Originally posted by Douglas Lee (40617)
      Bill,
      My '67 big block also had a brass plug.
      Ridge
        • 43279
        William-----
        I agree with the others; an NPT thread brass plug was used. Actually, I think a brass plug is a better way to go than a petcock, anyway. Petcocks often leak a little. They often stick and can be very difficult to open. They're almost always a bear to get at, too. When one thinks about it, one removes a plug every time one changes the oil which is a LOT more often than one drains the coolant. So, why should it be any different to drain the coolant as it is to drain the oil?
        • Bill S.
          • January 31, 2007
          • 396
          thanks for all the quick responses. now the trick will be wresting it out now that i have it all together. putting a shroud in a BB is no picnic.
            The Assembly Manual (section L36, sheet A5) shows the original release as a plug, P/N 444819, which was changed to a draincock (P/N 103647) per ECR 84133 on 1-19-67.
