1965 Front Grille - Question - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 409
    I've got a '65 front grille with "D&L" stamped on the lower stainless steel molding. Does anybody know if this could be or is the name of the OEM supplier?
  • Brian T.
    • September 30, 1990
    • 190
    Re: 1965 Front Grille - Question
    I have several of these mouldings that are NOS, I looked and did not see any markings. The manufacturer of the reproduction is a company in Oklahoma named Mar-K Specialized Manufacturing if that helps.
    • Ray K.
      • April 30, 2005
      • 409
      Thanks Brian. I'm actually not looking to buy a repro. I bought my '65 coupe a few years ago and I'm in the process of "cleaning up" the front end. I took the grille out and noticed the "D&L" stamped in the lower molding. . . Don't know if the grille is an original or not. Just thought I'd ask and see if anyone knew . . . . . .
        The original production supplier of the '65 grille was Douglas & Lomason (still in business, have been since 1902).
        • Wayne M.
          • March 1, 1980
          • 6414
          .. I took the grille out and noticed the "D&L" stamped in the lower molding. . . Don't know if the grille is an original or not.....
          Ray -- Can you be a little more specific ? side facing (up); ie. horizontal black bars, or facing fiberglass (down) ? near the middle or closer to drive or passenger side ? how tall are the letters ?
          I too have an original '65 grille on my bench; had a quick look and can't see anything.
          • Larry M.
            • January 1, 1992
            • 2701
            This might give us a clue that Ray's grill is probably the original.....or at least OEM.
            Larry
            • Ray K.
              • April 30, 2005
              • 409
              Wayne, D&L is stamped on the bottom side of the lower molding (on the short folded flange). If it would help, I could send you a jpeg, via e-mail.
              • Ray K.
                • April 30, 2005
                • 409
                John & Larry, Thanks. You made my day . . . . now I just gotta clean it up a little bit more . . . . . .
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Ray ---FOUND IT. Was on driver side outside surround end piece, facing fiberglass. If this is the same location as yours and all other originals, it merits becoming an item looked for during judging. On the other hand, if it was applied at random locations ...
                  Pics are off a grille that had some front end damage, road rash, etc.
                  Thanks for pointing out this stamping (sure beats our fixation on bolt head markings ).
                  • Brian T.
                    • 190
                    Now I know why I did not see it, I have the lower mouldings, not the corners. That is what it looks like on your picture.
                    • Ray K.
                      • April 30, 2005
                      • 409
                      Wayne, The grille on my '65 has "D&L" stamped on the lower molding, in two places. The "other" '65 grille that came as an"extra" part when I bought the car, has the "D&L" stamped on the outside surround piece, identical to yours. Sounds like Douglas & Lomason stamped their logo in two different locations (at least) . . . .
                      • James G.
                        • May 31, 1976
                        • 1556
                        Add it to the Judging Manual.
                        • Mike M.
                          Director Region V
                          • August 31, 1994
                          • 1463
                          Got it, Jim.
                          HaND
                          • James R.
                            • September 30, 2005
                            • 93
                            Just took my 65 out of storage this weekend. Using a mirror, I also found the D&L stamp on the lower molding but mine was only stamped on the lower left side.
                            Jim
                            • Jim C.
                              • April 1, 2006
                              • 290
                              Anyone know if the "D&L" stamp was ever found on a 66 grill? Thanks.
