T-10 Identification - NCRS Discussion Boards
T-10 Identification
  • David D.
    • December 1, 1977
    • 231
    T-10 Identification
    I have a chance to buy a transmission that I believe is suitable for a 60 Corvette but would like to verify it. The main case is T10 B-1, extension is T10h-7a, the side cover is T10 148B. The T10 148B fits with the NCRS Summer '86 article but the others are slightly off of the T10 7B Extension id and the T10 1B mentioned in the article.
    I have not seen the transmission but my nephew says the unit has D142 stamped vertically, WG Division and a W-1-C187 on the main case.
    Does this mean anything to the transmission guru's in the crowd?
    David Dawdy
  • David D.
    • December 1, 1977
    • 231
    Re: T-10 Identification
    OK. so I'll wait until I get it home to figure it out. main and ext are iron, hopefully it's worth 50 bucks.
    David Dawdy
    • Stewart A.
      • April 16, 2008
      • 1035
      Take some photos and post them I'll have a looky !!
      • Mark P.
        • May 13, 2008
        • 951
        The 1960 T-10 tail should be T10-7B. It shouldn't have an "h" in it.
        The side cover should not have a casting number. The date is on the inside.
        • Loren L.
          • April 30, 1976
          • 4104
          Sounds like it's for another application - Rambler, etc. Extension should be aluminum. But for $50, you have to play - if one gear is used in rebuilding the correct one, it pays for itself.
