62 Door glass - NCRS Discussion Boards
62 Door glass
  • Berndt U.
    • January 1, 1999
    • 72
    62 Door glass
    Hello from Berlin
    I look for the correct dated Glass code for my 62 FI Car.
    I think this Car has tinted windows all around.
    I have some side windows in Stock, but I am not sure
    witch one will fit my late 62
    Thank you for your help
    Berndt
  • Gary C.
    Administrator
    • October 1, 1982
    • 17773
    Re: 62 Door glass
    Berndt, are you looking for a glass vendor that sells correctly date window glass? Best, Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Berndt U.
      • January 1, 1999
      • 72
      Re: 62 Door glass
      Thank you, but I have some side windows for 61 and 62 Models, so I look
      for the correct date code for my 62
      • Gary C.
        Administrator
        • October 1, 1982
        • 17773
        Re: 62 Door glass
        Berndt, you just want to know what the date code is for your '62 window are - is that correct? Go to the 61-2 Judging Reference Manual Section 34 - Final Monthly Serial Numbers chart and look up your VIN number. Then go to Section 6 - Side Door Glass and look up a date code that is not more than 6 months before your car's production date. Recommend you order the 61-2 Judging Reference Manual. If you don't have the manual, go to Rob's site and put in your VIN to get your car's approximate production date. http://www.c1registry.com/index.php?uid=6063 Then post the date here and will give you the glass codes that could be used. Best, Gary....
        NCRS Texas Chapter
        • Mike M.
          • May 31, 1974
          • 8402
          Re: 62 Door glass
          Originally posted by Berndt Unnasch (31579)
          Hello from Berlin
          Berndt
          no first genmeration corvettes had tinted glass available from the vette factory. mike
