C1 PG Trivia - NCRS Discussion Boards
C1 PG Trivia
  • Roy B.
    • February 1, 1975
    • 7044
    C1 PG Trivia
    Probably never seen one of these for sale but if you have a C1 PG your rebuilding or bought this is the original torque Converter for Corvette only V8 ( different stale speed) having 35 bolts . Car has fewer bolts as seen here . I'm mentioning it because when buying a Corvette PG you need to look and see if it has the correct one.
  • Cecil L.
    • May 31, 1980
    • 450
    Re: C1 PG Trivia
    Roy,
    It was also used on pass cars with 2x4's, FI, and 348 engines according to my 60 Parts Catalog.
    • Edward M.
      • November 1, 1985
      • 1922
      Re: C1 PG Trivia
      OK, now how much of a difference does it make? What is the difference in stall speed?
      Obviously not a judged item, since you can't see it once it is in the car. Is it noticeably different that the standard passenger car torque converter
      when driving the car?
      • Stuart F.
        • August 31, 1996
        • 4676
        Re: C1 PG Trivia
        I just love automatics and all their peculiar operating terms, i.e. "Stall speed". Practically all the drag race cars use automatics now-a-days - all this lazy "point and shoot" stuff. It's not for me. Real men row their own.
        Stu Fox
        • Mike M.
          • May 31, 1974
          • 8409
          Re: C1 PG Trivia
          Originally posted by Cecil Loter (3596)
          Roy,
          cecil is correct and i suspect the 57 turboglides also used the 32 nut torque cionvertor.mike
          • Roy B.
            • February 1, 1975
            • 7044
            Re: C1 PG Trivia
            Roy,
            I dint know that!
            Because the Corvette generated such great fantastic RPM GM added more bolts to keep the seal from leaking.
