C3 door removal - NCRS Discussion Boards
C3 door removal
  • Jim M.
    • February 23, 2009
    • 233
    C3 door removal
    I'm thinking of stripping off the paint from my 69 so I can restore it to it's original color and it appears to me I'll need to take the doors off. Does anyone know the best procedure for doing this?
  • Steven B.
    • June 30, 1982
    • 4000
    Re: C3 door removal
    Jim, years ago I removed the doors on my '77. With the windows down I removed the door panel and vapor barrier first then disconnected the electrics for the power windows. I supported the full length of the doors with a homemade wooden stand and covered the doors with moving pads and supported the outside of the door so it would not fall over. Then I unbolted the hinges, bottom, then top and TWO of us walked it away from the car. These things are very heavy.
    Good Luck!
    • Jim M.
      • February 23, 2009
      • 233
      Re: C3 door removal
      Steven, did you have to remove the dash to get at the bolts holding the doors on? Jim
      • Steven B.
        • June 30, 1982
        • 4000
        Re: C3 door removal
        Jim, sent a reply via PM before I saw your post.
        Good Luck!
        Steve
