1963 Front Carrier Bracket - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5347
    On a 63 front Carrier bracket there is a small hole that allows a small bolt and screw to hold a bracket that holds the right emergency brake cable.
    Does anyone know if the bracket, bolt and screw that holds the cable is available anywhere.
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: 1963 Front Carrier Bracket
    Harry,
    Paragon has the cable clamp kit on page 48 #7529K. I don't know how close to original the repro parts look but the pic looks OK.
    I am not 100% on this but I believe the bolt has a captured split washer not what's shown in the picture. Hopefully someone will post a picture of screw and lock washer because I am not sure mine is correct.
    • Harry S.
      • July 31, 2002
      • 5347
      Tim, that must be it. I was using the wrong search argument.
      I just need the one on the right. I may as well go for them all as a frame off is in my future.
