63 Jute Padding - NCRS Discussion Boards
63 Jute Padding
  • Greg W.
    • August 31, 2005
    • 117
    63 Jute Padding
    I am going to ask the question again after reading this below.
    Does anyone know for sure on the padding.
    I found in the Technical Guide by Adams on page 34 "each piece was installed separately over jute padding."
    I thought that I read in another book just carpet with gray pad on the back?
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 63 Jute Padding
    Hi, when I took the original carpet out of my 63 Coupe it only had a grey foam on the back of the carpet, no padding whatsoever, my 64' Coupes have all had a press moulded 'tar paper' with jute type material glued under it. 64 verts just had the grey foam on the back of the carpet.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Alan A.
      • December 11, 2013
      • 5
      Re: 63 Jute Padding
      So what would you replace the grey foam backing with?
      • Harry S.
        • July 31, 2002
        • 5338
        Re: 63 Jute Padding
        Doesn't it come attached to the carpet.
        • Alan A.
          • December 11, 2013
          • 5
          Re: 63 Jute Padding
          That's what I was told by Al Knoch. It comes attached to the carpet by a spray adhesive. So, if that is the case then what do you do when you have to replace the underlayment?
          • Greg W.
            • August 31, 2005
            • 117
            Re: 63 Jute Padding
            It is a very thin layer of gray foam that is attached to the carpeting. This is glued directly to the floor. Therefore if you need to replace underlayment you will replace the carpeting also. Many people have put down the jute underlayment for comfort and noise first. If the car is going to be judged I would not put down the jute underlayment. If daily driver do it for sound and comfort.
