I am having trouble getting all my ac associated parts to line up in my engine compartment. I know it once did as I removed it for a rebuild of the entire system including the compressor.
I removed all brackets and repainted them along with having my original L46 350 engine rebuilt.
When I reinstalled the compressor lower mounting bracket it would not line up properly (when i tried to align the 2 holes to put a bolt through) with the compressor adjustor bracket that mounts on the lower front and this uses rh 2 waterpump bolt holes as part of its mount. Finally I had to remove the spacerwasher behind my french lock and now I can get the 2 bolt holes to align properly. Now between these 2 flanges (the lower mount bracket and front adjustor bracket) I have approx a 1/4 to 3/8 in. gap there. Is there a spacer that goes in there? This just doesn't seem right.
Also at the rear of my compressor where the 3 hole mounting bracket goes there is about a 3/8 in. gap so now do I put shims there? This car never had any before and I am using the same compressor over again.
Does anyone have any pictures of a a/c compressor installed and bolted up they could send me a couple of photos of: especially the lower bracket from a side view and the front bracket and how everything is supposed to mate up?
Jack, I have looked at the AIM but these poor reproduction drawings are confusing me even more. I do have the special stud in the exhaust manifold with the lower bracket and then the lw & nut.
Thanks for any and all help.
Jim Blakely
Jim Blakely
