67 exterior emblems - NCRS Discussion Boards
67 exterior emblems
  • Chris E.
    • November 3, 2006
    • 1326
    67 exterior emblems
    Has anyone bought the Trim Parts "NCRS approved" emblem and had it judged?
    The threads on my originals won't hold a nut any longer, so I need a new set.
    (Trim Parts "NCRS Approved Orange-Red emblem shown below)
    Browse RPUI's family of brands: The Right Stuff & Trim Parts. Everything you need to keep your vehicle in top shape.
    Chris Enstrom
    2011 Z06, red/red
  • Brian M.
    • February 1, 1997
    • 1838
    Re: 67 exterior emblems
    I am not aware of the NCRS approving any parts. I would use the original, you can make it work. JMHO
    • Ron N.
      • August 18, 2008
      • 243
      Chris, I purchased front "xflag" and rear "Corvette SR" emblems from Ecklers, had the car judged last year and got no deductions for the emlems.
      Ron
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Hi Chris
        Always opt to retain the original anything if at all possible.
        Actually the pins were not threaded, apparently just worn.
        A couple of options.
        Speed nuts collapse inward from over use or tightening.
        Sometimes pressing the center outward to its original convex position will solve the problem.
        Try new spead nuts in the existing grooves.
        And/or start a new groove.
        Good Luck!
        and HaND
        • Alan D.
          • January 1, 2005
          • 2038
          Chris,
          Agree on keeping original.
          You mentioned that the flags are Orange-Red Might want to hear from other 67 owners first to verify that.
          Reason I mention is that the 63/64 side flags are orange-red while the later flags (& NOS) are more of a burgundy red. Not sure if the front flags were left the orange-red while the side flags were changed to burgundy red. (not sure of year of change either)
          • Chris E.
            • November 3, 2006
            • 1326
            Oh, make no mistake, I will NOT be throwing away the original emblems. The question is really about what to put on the car for judging more than anything else.
            Here are some close up shots of what I have. Pardon the wax. Also note that the driver's side shaft on the nose emblem is much shorter than the passenger's side shaft.
            Chris Enstrom
            2011 Z06, red/red
              Nice photos! Where did you see the "NCRS Approved" note on the Trim Parts site? I didn't see it anywhere in the link in your original post.
              • Chris E.
                • November 3, 2006
                • 1326
                John, I swear it was there. I just checked the link again and it is gone. Not sure.
                It was next to the red/orange nose emblem......dunno.
                Chris Enstrom
                2011 Z06, red/red
                • Ridge K.
                  • May 31, 2006
                  • 1018
                  Chris, you're right. I saw it also, by clicking the link you provided, shortly after you started this thread.
                  I would say that "someone" at TrimParts, got a phone call, and thought twice about referring to a reproduction part as "NCRS color approved", which is my rememberance of how they worded it.
                  Glad you brought it to other's attention. Thanks,... Ridge.
                  • Brian M.
                    • February 1, 1997
                    • 1838
                    They finally got the color right???
