62 gas tank lid sealer - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2424
    What is used to seal the gas tank cover to the body? I have replaced all the jnuts and will be installing new screws w/washers. Where can you get the sealer?
  • Larry C.
    • April 1, 1980
    • 279
    Re: 62 gas tank lid sealer
    Strip caulking that can be bought at most auto parts stores. The caulking stays pliable and doesn't harden. The strips are about 3/16" in diameter (maybe less) and 12" in length, as I recall. Larry
    • Steven N.
      • April 30, 2002
      • 214
      John,
      The original sealer can be found at ACE Hardware. It is a white chauking and can be bought in rolls so you can use one continious piece. Use two rolled coils to circle cover. Yours, Steven J..............
      • John F.
        • March 23, 2008
        • 2424
        Thanks Steven! John
        Originally posted by Steven Neel (37940)
        John,
        • Bruce B.
          • May 31, 1996
          • 2930
          John F.
          My 62 Corvettes have all had black non-hardening strip caulk sealing the gas tank cover to the body section above the gas tank.
          Available at body shops or automotive supply stores.
          • Christopher R.
            • March 31, 1975
            • 1599
            John F.
            If it's an old-timer behind the counter, ask him for "dum dum."
            3M used to make a black kind and a grey kind. I know 1 kind is still available. Not sure if it's black or the grey.
            Usually can't see the caulk once the cover is installed.
            • Stephen R.
              • May 20, 2008
              • 302
              I bought the grey ( I think that they still make both) and it's found near where they keep the caulk for windows, frames etc.
              • Chuck L.
                • July 31, 1996
                • 260
                Mine was just like Bruce says, black non-hardening. Only one car to compare, though.
                Chuck Lyman
                Kansas City Chapter
                • John F.
                  • March 23, 2008
                  • 2424
                  Thanks. I found 3M Strip-Calk at Carquest....John
