53-62 Fan to Water Pump Hub Bolts - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    OK all you solid axle guys.....I can tell you any mid year bolt, thread and headmarking from memory BUT I have only worked on a few original Solid Axel cars. So my question is which of the bolts in the picture have you seen for the fan to water water pump hub.
    I have seen the WB and little 2, WB, UR, E and L8 (which I forgot to add in the picture). I have removed the NL4 bolt off of many many 53-62 Chevroles in junkyards but have not removed them from a Corvette. If any of you have I'd like to know.
    Thanks in advance for your time,
    Rich
  • Gary C.
    Administrator
    • October 1, 1982
    • 17945
    Re: 53-62 Fan to Water Pump Hub Bolts
    Rich, typically a "L" head mark in 56-7 fan bolts. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Larry C.
      • April 1, 1980
      • 279
      Rich, My original 1962 340 hp fan to water pump flange uses 4 hex head bolts that have six hash marks around a small "L" in the center. I could not get a good view of the heads you posted. Larry
      • Roy B.
        • February 1, 1975
        • 7044
        I agree
        • Mike E.
          • February 28, 1975
          • 5148
          Rich
          I've never seen the L8 or the NLB on a 61-62-- the WB with a 2 is also an odd one--generally I see WB, or E.
          Mike
          • Christopher R.
            • March 31, 1975
            • 1599
            Not sure about the manufacturer's marking. But I do know that those bolts had 6 hash marks. You need Grade 8 bolts there.
