Hi all;
Here is a question for all you 1963 guys.
This weekend I replaced both rear backing plates on my drum brake car.. The "thump" I had been writing about is finally gone. Turns out that whoever did the trailing arms last did not put in the correct studs.. they would spin in place and not permit the nuts to tighten.. hence loose backing plates! A new set of LI Corvette studs, pounded in place, did the trick... now everything is as it should be!
Anyway, I've got her all back together... My right parking brake is tighter than the left.. I still get some dragging back there when I drive. Now, when reinstalling the brakes I noticed that the cable to the left had more free play than did the cable on the right which leads me to believe why the one side is tighter..
Question... is there any way to deal with this and get the two sides "balanced" so to speak??? The entire parking brake cable system is new...
Joel
Joel
