69 fiber optics - NCRS Discussion Boards
69 fiber optics
  • Tom M.
    • 716
    69 fiber optics
    Is their a easy fix for c3 fiber optic line ? I can't get the license plate light to work or the parking light one side to come on
    thanks
  • Dick W.
    • 10483
    Re: 69 fiber optics
    Start by cleaning each end of the cable. Take a "Q" tip and rubbing alcohol to clean the ends. If it is broken, take a single edge razor blade and cut the ends of the broken section square. Butt the two ends together and use a section of heat shrink tubing to seal the joint.
    Dick Whittington
    • Paul D.
      • September 30, 1996
      • 491
      Re: 69 fiber optics
      The hard part will be finding where the breach is. Start at the light bulb and work towards the dash lenses. Many guys have been lucky enough to find painted over sockets at the bulb. Just scrape off the paint and you are good to go. Sometimes, the cable just pulls out of the socket at the bulb. On my 71 I had a fiber optic cable severed on one of the front park lamps. To repair it, I cut the cable square with a razor blade and joined the two pieces inside a piece of small vacuum tubing. I only half expected it to work, but it did. I couldn't tell the difference from one side to the other on the console.
      • Paul D.
        • 491
        Re: 69 fiber optics
        Dickie, we seem to be thinking alike although your typing skills are far superior. I am truly afraid.
        • Tom M.
          • 716
          Re: 69 fiber optics
          Thanks guys i will try that idea, hope i can find the break, where do the lines start/stop, do they run in the wire harness, or is it one line for each light ??
          • Paul D.
            • 491
            Re: 69 fiber optics
            One line for each bulb and usually routed along with wiring. The bundle of cables pass through the firewall next to the wiring bulkhead connection.
            • Tom M.
              • 716
              Re: 69 fiber optics
              thank you, hope spring gets here soon
