71 Corvette 454/425 Compression Ratio - NCRS Discussion Boards
  • Bruce N.
    • March 23, 2008
    • 83
    Is it 9 to 1 or 10 to 1? Is there any difinitive information on the 71 - 454 CR available on the Internet that I can print?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 71 Corvette 454/425 Compression Ratio
    Spec sheets I have show 9 to 1.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      • 15680
      Like all 1971 GM engines the LS6 was designed to operate on 91 RON unleaded gasolline, which is essentially the same as today's 87 PON.
      The actual as-built CR was probably closer to 8.5:1 than the advertised 9:1.
      If I was restoring one today I would assemble it with a true CR of 10.25:1, which would be fine with today's unleaded premium and the increased CR would improve torque/power across the range 5-10 percent and reduce fuel consumption by about the same amount.
      • Bruce N.
        • March 23, 2008
        • 83
        Thanks Guys,
        Where can I find a copy of the actual spec sheets?
        • Clem Z.
          • January 1, 2006
          • 9427
          try here. http://www.vettescape.com/
          • Bruce N.
            • March 23, 2008
            • 83
            Thanks Clem
