Power Steering - NCRS Discussion Boards
Power Steering
  • Bo B.
    • November 17, 2008
    • 29
    Power Steering
    I just get the parts to my power steering changing from no power to power.Valve ,cylinder,pitman arm,support bracket,long shaft are grey.Pump and pulley black.
    What is original color 1965?
    Installation manual is missing,anybody that have a copy so I can start before my supplier opens again.
    Bo
    • 43221
    Re: Power Steering
    Bo
    Bo-----
    valve-----semi-gloss black
    cylinder----semi-gloss black
    relay rod----natural or semi-gloss black
    frame bracket----semi-gloss black or natural
    pump-----semi-gloss black
    pump pulley----semi-gloss black for stamped steel pulley; cast pulley is usually natural but may be semi-gloss black
    add-on crank pulley (if used)-----semi-gloss black
    pitman arm----usually natural
    • Bo B.
      • November 17, 2008
      • 29
      Re: Power Steering
      Joe,
      Thank you very much.
      Any manual online maybe?
      Bo
        • 43221
        Re: Power Steering
        Joe,
        Bo
        Bo-----
        Nothing that I know of. However, you can purchase the 1965 Corvette NCRS
        Judging Guide and Technical Information Manual in print form from the NCRS Bookstore. If you own a 1965 Corvette, there are THREE publications that you MUST have:
        1) The above referenced JG and TIM;
        2) The Assembly Information Manual
        3) The appropriate Chevrolet Service Manual (1963 with 65 supplement)
        ALL are available from the NCRS Bookstore.
        • Bo B.
          • November 17, 2008
          • 29
          Re: Power Steering,Rebuilt set front end.
          Joe
          Do you have all the different colors on the parts in a rebuilt set I just got?
          Kit contains.
          4 ea of Corvette Upper Control Arm Bushing, 1963-1982 4 ea of Corvette Lower Control Arm Bushing, 1963-1982 1 ea of Corvette Idler Arm, 1963-1982 2 ea of Corvette Tie Rod Sleeve, 1963-1982 2 ea of Corvette Ball Joint, Upper, 1963-1982 2 ea of Corvette Ball Joint, Lower, 1963-1982 2 ea of Corvette Tie Rod End, Right Inner Or Left Outer, 1963-1982 2 ea of Corvette Tie Rod End, Left Inner Or Right Outer, 1963-1982 1 pr of Corvette Sway Bar Link Kit, Front, Rubber Bushing, 1963-1982 2 ea of Corvette Lower Control Arm Bumper, Front, 1963-1982 2 ea of Corvette Upper Control Arm Bumper, Front, 1963-1982
          Pls advice color on the different parts if possible.
          Bo
            Bo -
            I'm not Joe, but the upper and lower control arm bushings were painted black with the control arms after the bushings, retainers, and bolts were assembled to the arms, the idler arm, and the tie rod ends and sleeves were painted black as part of the steering linkage assembly from Buffalo. The ball joints are unpainted, as are the sway bar link bolts/bushings and control arm bumpers.
