Front Spindles 1969 - NCRS Discussion Boards
Front Spindles 1969
  • Ned T.
    • December 29, 2008
    • 188
    Front Spindles 1969
    Are both front spindles the same as far as left and right goes? I thought they were but I see a different casting, A36 on one and B36 on the other..
    • 43247
    Re: Front Spindles 1969
    Ned----
    The front spindles are the same for both sides for 1969-82 (in fact, they're the same for both sides for 63-67 and 1968, too). These spindles are forged steel pieces. The forging numbers you described likely identify the forging dies that were used. In this case, there were different dies and that's quite common.
    • Ned T.
      • December 29, 2008
      • 188
      Joe, Thanks for the information. Im doing the assembly on the chassis and I really couldnt see a differencr but you never know.
      Ned
        • 43247
        Ned
        Ned-----
        I should also have added that while the spindles are not side-specific, the steering arms which bolt to the spindle are very definitely side-specific.
