Seat Belt Buckle - D ring question - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 941
    I just bought a set of seat belts from Crane Corvette with new correct webbing and NOS 810 buckles for my 1960.
    The problem is one of the D rings fits very snug and makes it tough to insert and release. The other D ring is fine.
    Both D rings are stamped with the correct 235 number. The D ring that doesn't insert well is 92 thousanths of an inch thick and the D ring that fits well is 75 thousands of an inch thick.
    Was this much variation normal with these seat belt buckles ?
    Will I have a problem if I ever PV this car with a D ring that is snug ?
    I will probably try to exchange it but the belt will need to be resewn.
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: Seat Belt Buckle - D ring question
    Hi Mark
    No, originals would not have that much variance in the thickness.
    Yes, a PV problem, they should insert and release freely.
    Yes, you have the best solution, exchange if you can.
    HaND
