Should i change these two area's for judging - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    The following two areas of my nassau blue, blue int conv 65 ao smith car i believe to be factory original since my car had the original worn paint and interior,#1 my area below the wiper vents has very little blackout or more blue than black ,now the jg book say's complete area satin black should i change the area and paint it black or is this possible that other cars were this way.#2 the rear seat bolts and brackets on my car had blue on them also when i pulled the seats and original carpet. anyone else have this area painted car color, or should i clean the bolts of paint and paint the bracket satin black. Thanks again for everyone that has answered my post........jim
    Re: Should i change these two area's for judging
    Jim -
    The area below the vent grilles should be blacked out; from your description, it might take a minor deduction for condition as is - depends how it looks.
    The '65 rear seat brackets were originally dip-primed black, but they were installed in the Body Shop and typically picked up some color overspray when the body was painted - I'd leave it alone.
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Jim
      Don't touch anything!
      The area below the wiper grills had varying degrees of coverage.
      The rear seat "U" retainer & hardware was in position before the car was painted. ('65's & "66's)
      I would suggest that you hook-up with your local Chapter for an experienced close-up examination.
      HaND
      • Jeff G.
        • October 25, 2006
        • 187
        I agree with Mike, don't change a thing. I'm not a mid year guy but do I know the 68-72 cars had over spray around that wiper area. If you look very closely, you can see it on Patricks' 72 Bowtie. My original paint 69 has it also...
        Webshots, the best in Desktop Wallpaper, Desktop Backgrounds, and Screen Savers since 1995.
        • Jim R.
          • June 30, 2001
          • 643
          Thank's guy's for the quick responce......jim
          • Michael H.
            • January 29, 2008
            • 7477
            Originally posted by Mike Murray (25129)
            Hi Jim
            HaND
            I agree, the air inlet area is an area that often had slim blackout coverage. Many originals look like they were "sorta" hit with black, leaving quite a bit of body color around the outer portions.
            I don't think the seat rear "U" shaped brackets/bolts were in the body when it was painted though. Possible I suppose, but not likely.
