Paint recommendations for chassis & firewall blackout - NCRS Discussion Boards
  • Steve G.
    • December 12, 2008
    • 192
    I had heard Krylon semi-gloss black was a good choice for frames, and semi-flat black for firewall and inner fender blackout. I can't find semi flat in local stores. Are there other recommendations for these paints? Is SEMS satin black a good option? Steve
  • Frank P.
    • April 1, 1985
    • 64
    Re: Paint recommendations for chassis & firewall blackout
    Krylon K01613 is Semi-Flat Black. Only available from industrial type suppliers. Do Not use the Krylon 51613 from the retail suppliers. It is not the same formula and cannot be recoated.
    • William L.
      • December 1, 1988
      • 944
      Steve
      I like the SEM 39143 Trim Black. Any good Auto Paint store will have it.
      Bill
      Bill Lacy
      1998 Indy Pacecar
      • Steve G.
        • December 12, 2008
        • 192
        Thanks for the input guys. Do you have recommedations for the brake booster, and chassis? Do you recommend an industrial version for those as well? Does anyone have a list of suggested paints / finishes for all items under the hood of a 1970? Steve
        • Jim H.
          • April 1, 2002
          • 112
          You can order a case from:
          • Jim H.
            • April 1, 2002
            • 112
            I have used Krylon tough coat semi-flat. Also, you might want to powdercoat your frame if it is pitted. Now, it is not correct though very good coverage. In my case, I powdercoated the frame first went back over the frame sanding and grinding then painted the frame once more with krylon tough coat paint. I work well for me. Now, my car is not correct or judged.
              • 3415
              Hi Steve,
              There are many finishes used under the hood... painted, plated, and natural. The most complete list I've seen is in the 70-72 TECHNICAL INFORMATION MANUAL on page 105. The list has both chassis and under hood finishes. It's not complete, but is a good place to start, for info.
              Getting to see a Bow-Tie car is really good way to see what the finishes are... up close.
