First use of bleeder valves for wheel cylinders? - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 832
    Hi all,
    Someone sent me this pic of one of his wheel cylinders (1959). As the picture shows, there is no bleeder valve. Instead, there is a plug that must be removed and then replaced after bleeding. He thought this was correct on early Corvettes.
    Anyone know if these were used any time in the past for any car and, if so, when was the switch made to bleeders that just need to be loosened as we have now?
    Bob
  • Jim L.
    • September 30, 1979
    • 1817
    Re: First use of bleeder valves for wheel cylinders?
    Originally posted by Bob Baird (39424)
    Hi all,
    Someone sent me this pic of one of his wheel cylinders (1959). As the picture shows, there is no bleeder valve. He thought this was correct on early Corvettes.
    That looks like Bubba's work to me. I've never worked on an old Chebby that didn't have bleeder valves.
    Jim
    • Ernie F.
      • March 31, 1975
      • 107
      Jim
      Bubba at his best! I've had chevys from a 49 up to 07 and never seen a plug used. Man that would take some creative bleeding too! "Hold the pedal down, keep holding, keep holding, no don't let up, keep holding! OK. . . Got it, pump. . . Keep holding!
      Ernie
        • 15706
        That thing between the two attaching screws sure looks like a bleed valve to me!
        The unused "pad" may simply be for applications that have the input lines on the same side, so the casting can be used for both right and left sides in applications where the input pipe comes in at the front or rear rather than perpendicular at the center.
        • Ian G.
          • September 3, 2007
          • 1141
          I think its original. I have a 821 wheel cylinder in the Delco Moraine tin can that has a bolt that goes into the bleeder valve, instead of a regular one-piece bleeder valve just like what that looks like in Bob's pic. There should be an external tooth washer there that is missing. CC sells them also:
          191015 BRAKE BLEEDER VALVE SET - 3/8" 24 - 4 PIECES
          It would be hard to bleed them though, since the attachments are rubber. maybe in the 50's they had a screw-in hose?
          • Perry M.
            • January 1, 1977
            • 325
            That's the way it is on my 57 Nomad. The screws are simply plugs. The larger hex head is the bleeder.
            • Jim L.
              • 1817
              I stand (or type, in this case) corrected. Yep, that's a bleeder valve, the larger hex being the valve. And to use it without making a mess, you would indeed screw a fitting into the valve in lieu of the bolt.
              I've never seen such a thing.....
              Thanks to the OP for the posting.
              Jim
              • Gary C.
                Administrator
                • October 1, 1982
                • 17971
                Bob, hex head bolts were used at least through the '57 MY for Corvettes. Not sure when the General started using bleeder valves. The revised 56-7 JM is going to state that hex head bolts were used. Gary....
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Ian G.
                  • September 3, 2007
                  • 1141
                  I'll see if there's a date on my Delco tin can. The cylinder is a 821 inside.
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17971
                    '58 P&A shows Group # 4.666 part # 5454315, 10-32x1/4 inch hex head bolt. 61 P&A shows a bleeders. Didn't take my 59-60 books out to check. Gary....
                    NCRS Texas Chapter
                    • Ian G.
                      • September 3, 2007
                      • 1141
                      cool deal. Saved by the book
                        • 43295
                        Perry-----
                        That's correct. The screws are simply plugs. The bleeder operates in the usual manner after the plugs are removed. Later bleeders used an integral nipple instead of the screw/plug. Some of these had a rubber snap-on cap, but I don't know if later C1's equipped with this type bleeder ever used these.
                        So, when did the change occur during the C1 period? I can say that, for sure, the early style (i.e. with screw plug) was used through 1958. However, I don't know, for sure, when the later style began. I believe it was either for the 1959 or 1961 model year, though, or, perhaps, sometime in between.
                        • Jim L.
                          • 1817
                          I just checked my '59-'60 passenger car shop manual. The manual makes it clear that the change was in place by '60, equally clear that the screw plug style was still being used in '58, and ambiguous about what was in use in '59.
                          Jim
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17971
                            59 P&A shows bolts, 60 P&A shows bleeders in group 4.666 Gary....
                            NCRS Texas Chapter
                            • Bill M.
                              • April 1, 1977
                              • 1386
                              I just dug my '59's original wheel cylinders out of the "junk" pile, and they have the bolts. My car is 2528.
