1967 big block hood paint and stripes - NCRS Discussion Boards
  • Charles A.
    • July 31, 1980
    • 180
    I have Steve Lavignes pictures and read all of the archives. I am trying to simplify the measurements. The pictures and measurements are clear on the lower valance but the measurements in the AIM for the hood refer to center lines and measurements in half widths. I have tried to use those and came up with the following calculations.I am starting at the valance and measuring back toward the windshield.Is it correct that the center solid paint at the top of the valance and bottom of the hood is 4" wide and the solid paint just below where the hood rises is 9.12" On the elevated part of the hood is the solid paint 17.62" wide? From the side of each of the solid painted areas you would then go over 5/16th of an inch and paint a 1/8th inch stripe? Then you would shape the stripe on the valance as shown in Steve's pictures. Correct?
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: 1967 big block hood paint and stripes
    Hi Chris
    Yours seems to be an accurate interpolation of the AIM.
    One question, I can't see your reference to the 9.12 dimension.
    HaND
    • Charles A.
      • July 31, 1980
      • 180
      You take the 8.43 dimension to the top of center of the lower part of the hood and paint over to 3.87 from the side of the raised area. If so you have painted 4.56 of solid color on one side. You multiply that time the 2 sides and you get 9.12. I am sure you will see the 8.43 and 3.87 on page G 379 of the manual. Hope I am reading it correctly. I have a new painter and I am trying to make it as easy for him as possible. The car is being painted in base coat clear coat. Anyone know the timing between marina blue base coat, tape application, black stinger color and clear coat?
      • Ridge K.
        • May 31, 2006
        • 1018
        Charles, did you get your questions answered about the stripe dimensions. I can take measurements if you need them. Just let me know.
        • Craig O.
          • July 31, 1983
          • 207
          Charles, your paint supplier should be able to give you the dry time, tape to base and clear specs. I know the base uses an activator hardener so the window to top coat is specific for adhesion. I believe you should be able to do the whole hood in one day.
          • Charles A.
            • July 31, 1980
            • 180
            Thank you believe we have it figured out.
            • Stephen L.
              • May 31, 1984
              • 3162
              Charles, I painted the stripe over Marina Blue and then clear over the whole thing. Drying time was less than 1 hr between coats. The black doesn't need to be a heavy coat. This keeps the edges buried in the clear so there is no "step" at the color change after final buffing. Use the 3M striping tape Smooth green stuff......not green masking tape. Definitely install hood before stripe layout to get an accurate transition of the stripe from front valence to hood.
              If you are painting Marina Blue you must paint car "loosely assembled" IMHO!!! If you don't, there is a high risk of paint mismatch. Its very frustrating to see a paint color change when under flourescent lights between the doors, headlite buckets etc. Don't ask how I know except that I repainted the entire car because an "expert" told me there would not be a problem painting in pieces with the piece "orientation" as it would be mounted.
              If you want to discuss further give me a call (864)963 2991
              • Charles A.
                • July 31, 1980
                • 180
                One last question. I am a little unsure on the width of the body color stripe on the upper part of the hood between the center large area ( black in my case marina blue car) and the 1/8th black stripe. Is it still 5/16th as the lower part of the hood and valance or is it 3/16th?
                • Ridge K.
                  • May 31, 2006
                  • 1018
                  Charles, mine is 5/16th. My car is 14,0XX, sitting in it's original acrylic lacquer. Marina blue, black stinger.
                  Let me know if you need additional photos.
                  Ridge
                  • Charles A.
                    • July 31, 1980
                    • 180
                    Ridge you made my day since it has been painted. My neighbor has one that is wrong is why I questioned it. If you have a minute send me a hood pic to carnold@coj.net
                    • Ridge K.
                      • May 31, 2006
                      • 1018
                      Charles, you have mail!
