C1 steering third arm brg replacemant - NCRS Discussion Boards
  • Jerry W.
    • January 27, 2009
    • 588
    I've searched the archives for info w/o result
    Has anyone replaced the third arm brg and stud ? remove support brkt first ?
    Any advice would be appriciated.
  • Larry C.
    • April 1, 1980
    • 279
    Re: C1 steering third arm brg replacemant
    I am sure you will find the instruction you need in the ST-12 manual, or Corvette Servicing Guide, which is available for purchase thru NCRS and other sources. It is a valuable source for any early Corvette restorer.
    • Jim H.
      • April 1, 2002
      • 112
      I would take it off as one unit then get the old bearing out on a workbench. The bearing is a pain to get out. It takes some work.
      remove the support bracket from the frame then remove draglink and tie rods from the third arm.
      • John T.
        NCRS Financial Officer
        • January 1, 1983
        • 292
        Re: C1 steering third arm brg replacement
        To remove the bearing. From the ST-12
        "1. Remove grease and dirt seal. 2. Remove snap ring from inside arm opening. 3. Place nut on stud and lock nut securely in a vise. 4. While holding other end of arm, use a hammer and tap around arm opening to remove stud and bearing."
        Good luck
        John
