Distributor Curve Specs - NCRS Discussion Boards
  • Andrew P.
    • January 4, 2008
    • 36
    Hello,
    I am in the process of rebuilding my distributor and was hoping that someone could verify these Distributor Specs. (Joe L?)
    Dist # 1112050
    Dwell: 29-31 Deg
    Centrifugal Advance: (Crank Deg @ RPM)
    0@865, 2@1335, 11@2400, 18@4200
    Vacuum Advance:
    0@8", 15@ 15.5"
    Andrew Papanicolaou
    71 350/4spd
  • Donald L.
    • September 30, 1998
    • 461
    Re: Distributor Curve Specs
    Try this link.
    http://www.lbfun.com/warehouse/tech_...ve%20specs.pdf
    • Andrew P.
      • January 4, 2008
      • 36
      Hello,
      Thanks for the reply and link. That is where I got the specs from as well. Just wanted to make sure they were accurate as there was no author listed.
      Andrew Papanicolaou
        • 15631
        Delco book says:
        Dwell 27-31* with a footnote that this is satisfactory range but setting to 29* gives a .016" point opening
        Start distributor 650 rpm = 0-2*
        1200 rpm = 4.5-6.5*
        2100 rpm = 8-10*
        It should have a 1973437 vacuum unit
        7-9 in Hg to start moving
        16-18 inches Hg for maximum advance
        Maximum distributor advance for vacuum unit = 8*
          Originally posted by Andrew Papanicolaou (48361)
          Dist # 1112050
          Dwell: 29-31 Deg
          Vacuum Advance:
          0@8", 15@ 15.5"
          Andrew -
          Those specs are straight out of the 1971 Chassis Service Manual (Specifications section, page 19), except the CSM shows the vacuum advance max as 12* @ 15.5" Hg.
