858 head rework - NCRS Discussion Boards
858 head rework
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 858 head rework
    Originally posted by Joe Raine (45823)
    Clem,
    What is the best angle for the back cut on the valves? Is that done on both the intake and the exhaust valves?
    Joe
    Pretty sure it was/is a 20* cut off the back side. I'll look in the book.
    Remove material on the back side of the valve so the width of the 45* cut on the valve matches the width of the seat in the head.
    ......Found the instructions from the boys in the back room at GM.
    • Joe C.
      • August 31, 1999
      • 4598
      Re: 858 head rework
      This guy is one of the best:
      How does acid porting add air flow to cylinder heads and intake manifolds? Acid porting is the enlargement of the entire intake port using chemical treatments. After “Acid Porting” the port looks very much like stock with the original casting … Continue reading →
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Re: 858 head rework
        http://castheads.com/acid_porting.php
        One of the worst things for HP that can happen to an old 60's big port big block head used on the street is "enlarging the intake ports". Makes a bad design even worse.
        • Joe C.
          • August 31, 1999
          • 4598
          #19
          Re: 858 head rework
          Michael,
          I didn't say that the intake ports should be enlarged. I do say that these folks are one of the best porters of old fashioned cast iron heads. Their website stresses SBC Chevy heads, but I believe that they are among the best with BBC heads as well.
          Strike the above website, and add this instead.................I only wanted a link to Brzezinski, and the "acid porting" page came up instead:
          We are #1 in Cylinder Heads since 1980. UnderCover cast iron cylinder head modification, acid porting vortec cylinder heads & manifolds.
            • 15692
            #20
            Re: 858 head rework
            For durability on a road engine the seat surface on the valve should overhang the head seat by .010" on both the upstream and downstream side.
            • Joe R.
              • May 31, 2006
              • 1822
              #21
              Re: 858 head rework
              I talked to the machinist last week. The valves are stainless steel, the manufacturer is Ferrea. The viton seals are positive seal type made by P.E.P. The mfr. of the studs is PBM. Should I go back to GM studs? What is the GM part number?
              Joe
                • 15692
                #22
                Re: 858 head rework
                Joe
                Those are probably okay. Get the part numbers and look them up. Likely the mfgs. offer data on them.
                What about the valve springs... mfg.? part number? specifications? Are they a proper match for the ...143 cam?
                • Michael H.
                  • January 29, 2008
                  • 7477
                  #23
                  Re: 858 head rework
                  Weren't the valves .100" longer than original? May be difficult getting proper on seat spring tension if that's the case.
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    #24
                    Re: 858 head rework
                    Duke,
                    I have already purchased GM part # 12371061 (set of 16 GM part # 3970627 springs). That's what I'll use.
                    Joe
                    • Joe R.
                      • May 31, 2006
                      • 1822
                      #25
                      Re: 858 head rework
                      Michael,
                      I don't plan on using the Ferrea valves. I'll use the Sealed Power replacements for the GM valves. I think I'll be OK on length then.
                      Joe
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        #26
                        Re: 858 head rework
                        Michael,
                        Joe
                        Ok, that will work.
                        • Dick W.
                          • 10483
                          #27
                          Re: 858 head rework
                          I believe that you will find that some on the top performance engine builders today use Ferrea valves. I would have no problems using them in a street engine.
                          Dick Whittington
                          • Joe R.
                            • May 31, 2006
                            • 1822
                            #28
                            Re: 858 head rework
                            Dick,
                            That's good to know. But they are not the right size for BBC. They are 0.1 " too long. The stem diameter should be 3/8 ", is 11/32 " (SBC).
                            Joe
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              #29
                              Re: 858 head rework
                              Dick,
                              Joe
                              the GM BBC HP crate engines use the 11/32" stem valves and the ones GM sells now are 11/32" stems. it makes the valve a lot lighter and helps with at what RPM you get valve float. like i posted before since you are not going to be racing i would not change a thing. if you want more power build a stroker short block. you can make up the .100 length difference with offset keys and valve spring shims so you can use the GM spring.
