65 396 fan configuration - NCRS Discussion Boards
  • Jaime G.
    • April 1, 1988
    • 480
    The 65JM describes the fan for BB 396 as having flat rivets. The AIM does not specify. I have repeatedly been told that for 65 only the BB fan configuration has round rivets. Can you guide me to the correct fan configuration.
    thanks
    JG
  • Grant W.
    • December 1, 1987
    • 407
    Re: 65 396 fan configuration
    Hi Jaime
    There was some discussion about the fan blades and with pictures. Basically its flat rivots. H and 66 and Front stamped on the hub of the fan.
    Thanks, Grant
    • James W.
      • December 1, 1990
      • 2662
      Jaime
      In this thread you will see my pictures of the original fan from 1965 Corvette #22161. The pictures show the rivet style very clearly.
      https://www.forums.ncrs.org/showthrea...61156&uid=7947
      Hope this helps.
      James West
      Omaha, NE.
      • Peter L.
        • May 31, 1983
        • 1930
        Grant - I believe the fan blade assembly with the H and the 66 is for the 1966-1967 Big Block. The 1965 396 fan blade assembly was different. Pete
        • Jaime G.
          • April 1, 1988
          • 480
          thanks James
