63 Hood Release Cable Repair - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 304
    Has anyone successfully removed and re-installed a new cable into the handle?
    Steve Gansky
    Newtown, (Bucks County) PA
  • Harry S.
    • July 31, 2002
    • 5299
    Re: 63 Hood Release Cable Repair
    Steve, I've never heard of anyone. The one solution I suggested was to cut and drill out the old wire. Ensure you know the length of the new wire you need, a little longer will be OK.
    Take the handle and the new wire to a jeweler and have them silver solder the wire into the handle. Might be expensive. Then sand, clean and paint the handle id needed.
    When I broke mine I found a handle in rough shape at Carlisle for $5.00. The wire was the correct length. I sanded and painted and it's been fine for a long time.
    Good Luck
    • Stephen P.
      • September 30, 2002
      • 116
      I drilled out my handle, filled the hole with JB Weld and forced in the wire. It's worked with no problem for about 3 years.
      • Stephen G.
        • January 1, 2002
        • 304
        I was thinking of trying to drill it out and attach a new cable. Never a dull moment!
        Steve Gansky
