72 Seat Mounting Bolts - NCRS Discussion Boards
    • 6960
    What Are The Correct Marking For Seat Mounting Bolts And What Type Of Bolts, Some Have Pointed Ends And Some Are Flat, I Believe Ive Got A Few Mix And Matched Bolts. Thanks Ed
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 72 Seat Mounting Bolts
    My 70 had SEMS indented hex head, pointed end, self-tapping screws with captured washer. That will probably work for your 72, but a different headstamp even on a 70 would not be surprising.
      • 3422
      Hi Edward,
      The bolts on my 71's seat track mounts have an odd looking headmark.
      Its a large capital B with a very small capital H in it's center. There are also 3 hash marks, 1 each at 3, 6, and 9 o'clock. All 8 are the same.
      They don't have pointed ends.
      So another possibility for you to look for.
      • Bill L.
        • February 1, 2004
        • 1403
        My 70 has anchor head marks with no point.
        Bill
        • Steven G.
          • November 17, 2008
          • 348
          I have looked at a 70 and all have flat ends, no points or self tapping ends, captured washers (5/16" x 1" bolt), 1/2" hex. head, course thread, and appear to be the same type bolts, but a mix of markings like mentioned and other markings not mentioned unpainted natural finish. I am thinking they may not always be a matching set, more input may be needed. Steve
          • Pat M.
            • April 1, 2006
            • 1586
            I agree based on my limited experience, but I think the bolts were gray phosphate plated, like the seat rails.
            • Rich P.
              • January 12, 2009
              • 1361
              Hi Edward,
              Alan, starting in 69 cars I have seen your B/H (not to be mistaken for the typical B&H) bolt.
              "typical" 67-72 seat mount bolts are flat tip w/a flat washer
              Rich
                • 6960
                Guys Thanks For The Responses, I Guess There Are A Mixture Of Head Markings, Are All The Bolts Indexed Heads W/ Captured Washers , Flat Tips. A Few Of You Didnt Specify.and One More Question The Bolts On Seat Tracks Rear Closest To Left And Right Doors Nuts And Bolts, Mine Seem To Be In 72 Or Maybe There Theres Something Missing.
                  • 3422
                  Hi Edward,
                  On my 71 the outer rear track bolt has a plate with a tapped hole riveted to the under body. I believe you can see it in this picture. I'd 'think' 72 would be the same?
                    • 6960
                    Alan,
                    Ill Look This Weekend To See If Theres A Brackets Riveted To The Floor , Maybe Its Stripped Out On Both Sides, It Think Its Strange That Both Outter Bolts Would Be The Same.
                      • 3422
                      Hi Edward,
                      The bolts and plates get pretty rusty in that location and the bolts are easy to twist off. Perhaps that's what happened in your car's past.
                      • Steven G.
                        • November 17, 2008
                        • 348
                        Yes Edward, definately all have indexed heads with captured washers. Steve
                        • Bryan M.
                          • April 1, 1999
                          • 386
                          Here is a pic of what the seat mounting bolts on my 72 look like.
                            • 6960
                            Alan,
                            I Looked At My Outer Seat Brackets Today There Still There But No Threads Left, Stripped Out, I Guess Ill Put Some Heil Coils In To Repair.
                              • 3422
                              Hi Edward,
                              The brackets are reproduced pretty nicely. I don't know if that interests you or not. The heli-coil is more straight forward.
