wet sump oil pump casting failure - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    The fun never ends. I am in the process of converting my dry sump road race 327 to a wet sump motor. I have a melling 155 HV. Have any of you old racers every expirienced a casting failure of the pump. melling warns that when used with solid motor mounts the casting may fail. I don't want to go back and change this out but I will. I'm suspicious that Melling may be trying to sell me the more expensive version of the same pump. Have any of you old racers ever seen a casting failure on this OEM type pump?? Jerry
  • Dick W.
    • 10483
    Re: wet sump oil pump casting failure
    Jerry, only failures that I have seen was from debris, needle bearings from the rockers in both cases, in the pump. I could maybe visualize a harmonic vibration that might do the damage, but that would be a far streach
    Dick Whittington
    • Jim L.
      • September 30, 1979
      • 1817
      google: "melling oil pump failure" You'll get a bazzillion hits. On one of the pages I found this:
      Here's a link to a page with a couple of pictures that show the difference between the select and regular pumps:http://www.jalopyjournal.com/forum/s...hlight=melling
      Jim
      • David G.
        • May 31, 1980
        • 275
        Jerry, I just installed a M155 oil pump in my race car. I read the warning that came with the oil pump concerning the potential failure with solid motor mounts. I compared the new pump with several other pumps that I have and it looks like it was redesigned with less mass to the casting.
        Dave
        • Clem Z.
          • January 1, 2006
          • 9427
          make sure you radius grind the area where they machine for the bolt so you have no sharp corners which cause stress risers. you can fab a metal brace from the pickup screen to a main bearing cap bolt or windage tray stud.
          • Jerry G.
            • April 1, 1985
            • 1022
            You guys are a wealth of knowledge. Thank you very much. I will pull the 155HV and get a select. I tend to agree with the inferior casting material idea. Jerry
