66 Dash Wiring Harness - NCRS Discussion Boards
  • John M.
    • January 1, 1998
    • 813
    This car is a 66 with emergency flasher option. The wiring harness that came with the car, in a box, seems to check out with the aim except there are three wires going into a connector with a clip on the side of it. Wires are #12 red, white, black. The position would end up near the radio and heater controls. Can't find these wires or connection in the AIM under any section including C60, AC. Car does not have AC. Any ideas?
    John McRae 30025
  • Philip C.
    • December 1, 1984
    • 1117
    Re: 66 Dash Wiring Harness
    John The four way harness just connects in between the sterring column harness connector and the main harness harness connector. Phil 8063
    • Philip C.
      • December 1, 1984
      • 1117
      That white red black sounds like the power antenea connector Phil 8063
      • Jack H.
        • April 1, 1990
        • 9906
        Then, a single red wire extending from the 'sandwich' connectors of the V74 option daisy chains to the fuse block to pickup power...
