Fuel Line Clips 69 427 - NCRS Discussion Boards
  • Ned T.
    • December 29, 2008
    • 188
    Since the 427/400 does not have a return fuel line, does it take different clips that hold it to the frame. I bought new fuel line clips but they are the wider ones used for the double line to the tank. Is there a single wide clip that should be used that would look more like the brake line clips?
    • 3416
    Re: Fuel Line Clips 69 427
    Hi Ned,
    Corvette Central does show a clip set (193077) for a 69 without the fuel return line. Perhaps you could check with them to see if the clips are in fact the configuration you need and whethe you can buy just what you need.
    • Ned T.
      • December 29, 2008
      • 188
      Alan, I got this set from Bairs and thought they would be "correct". Ill have to try Corvette Central, and I might also might make a call to Paragon. Thanks for the info.
      Ned
