Need help with Cluster bulbs - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    I have had my '64 Cluster rebuilt and we also did another friends '64 Cluster as well. The issue is he has different light bulbs in his wire end bulb sockets, than I do.
    So....the question is:
    1) What are the type(s) of bulbs that are used in the cluster?
    2) Are they still available, other than Asian made lights, and if Y, where?
    TIA,
    David
  • Mike E.
    • February 28, 1975
    • 5140
    Re: Need help with Cluster bulbs
    Toward the rear of the owner's manual specifies what bulbs should be used in specific instances.
      Your copy of the Owners Manual lists the different lamps used by location. In general, you're not going to find Made in the USA replacement lamps these days unless you happen to get lucky finding old stock at various auto parts stores...
      Most incandescent lamp manufacturing has moved off shore, but that doesn't necessarily mean all foreign lamps are 'junk'... I've found those made in Hungry are pretty good quality!
      • Jean C.
        • June 30, 2003
        • 688
        Jack, you're gonna get responses from some folks....bulbs made in Hungry?
        Best regards,
        • James R.
          • September 30, 2005
          • 93
          Lectric Limited have cluster light bulb kits. I bought one last fall when I did my cluster. It included all the bulbs that you need. Cost was $21.00 plus tax and shipping.
          Jim
          • David D.
            • January 1, 2005
            • 416
            Thanks for the replies......
            David
