I'm trying to find out if the directional signal harness passes over or under the speedo cable on its way to the switch on the column.
Also the brown horn wire connector (harness side) has a clip on it. It clips to ??? and does the horn wire as it leaves the cluster area pass over or under the bird cage rail as it heads to the column.
