Can some one please post a pic of the front and rear of a known origional 65 396 fan blade I know they are out there but in all my searching i have not found an origional one . thanks for your help Don....
396 Fan blade
Re: 396 Fan blade
Posting a picture isn't going to help you much... The difference between the 396 BB fan and the standard SB fan is SO slight, they're almost impossible to tell apart unless you REALLY know what you're doing!
There's an overall diameter difference of 1/8-inch (good luck in measuring/verifying that!) and something like 3-degrees of pitch differential in the blades.
If you want/need a 'correct' 396 fan, then my suggestion is to go buy the reproduction from Paragon. It was tooled using a 'loaner' from long time NCRS 396 expert, Charlie Stewart, now deceased....- Top
Re: 396 Fan blade
Here is a thread from a previous discussion
https://www.forums.ncrs.org/showthre...61156&uid=7947Keith Burmeister- Top
