72 Sm Block Drive Shaft - NCRS Discussion Boards
+ More Options
Posts
    • 6950
    Ive Justed Fininhed Cleaning And Preping Half Shaft And Drive Shaft, Is There A Part No. Painted On Half Shafts And Drive Shaft For 72 Coupe Sm.block, Thanks Ed
    • 43259
    Re: 72 Sm Block Drive Shaft
    Ed-----
    There is no part number stenciled or otherwise appearing on half shafts. I have seen part numbers stenciled on some driveshafts, but I don't know that all had them.
    For 1971-75 there was only one driveshaft present in the Corvette plant for all applications. So, I would not think that they would have needed to be identified.
      • 6950
      Joe, As Always Thanks For The Response I Will Continue Tommrow W Finsihing Touchs On Shafts.thanks Again Ed
        • 11681
        Driveshaft:
          • 6950
          Patrick,
          Thanks For The Picture,Ive Noticed You Have Alot Of Pictures Posted Of Your 72 Car, Do You Have A Web Site With The Pictures, What Month Was Your Car Built,
          My Driveshaft Had Black Painted Sprayed Over Rust,I Used Paint Remover To Clean -up, There Was No Signs Of A Stenciled Part No. Does Mean There Wasnt A Sometime In Its Life, It Was A Unmolested Car When I Got It. Is It Possiable There I Is A Production Date Where They Stopped The Driveshaft Stenciling. Thanks Ed
            • 11681
            Patrick,
            Ed,
            seeing as my car is from the first week of June 72, I doubt that they stopped adding the stencil.
            Pictures are at http://rides.webshots.com/album/5638...oi?vhost=rides
            • Paul C.
              • November 12, 2007
              • 511
              I have the stencil for my 71 driveshaft but not the paint. I don't really want to buy a whole can and pay shipping for the one stencil. Does anyone know where you can buy the yellow spray stencil ink or the color that would match it from a local paint or automotive store. Can you just use a particular shade of yellow?
              Thanks Paul
